Suggestions --> Ceiling Mounted Rail System
Hello,
I teach in a public high school and I'm considering making a robotic system that would enable me to send and receive hard-copy documents to & from students in my classroom. The floorplan is something like what's in the image below. I'd like any suggestions for a ceiling mounted rail system. I was thinking that when the robot moves over the workstation where a document would be either delivered or received, a container of some sort would deploy down to accompany the transaction - thinking winch here. Also, it seems like the system should be close to the ceiling for stability issues. The ceiling height is ~10', and 2'x2' ceiling tiles are installed.
Is this necessary? Of course not. Could it be educational & entertaining? Absolutely! [noparse];)[/noparse]
Scope
Post Edited (Scope) : 2/1/2010 8:45:50 PM GMT
Scope
- Stephen
I agree the floor-based system would most likely be easier & quicker to create - very good observation, thanks. My wife said the same thing - great minds think alike.
Franklin/Stephen, I don't see why I couldn't attach something through the tiles. I could buy the tiles, drill holes in them, and perhaps create a structure that would support something like this sketch below.
The overhead system may never come to pass, but it's a joy to contemplate.
Thanks for the comments.
Duffer
Any technology, sufficiently developed, is indistinguishable from magic.· A.C. Clark(RIP)
PG
The rails and beam don't need to contain any electronics or motors, just some bearings. The car can contain all the motors and electronics. It could just move itself to one of the rails, pressing a wheel against the rail and using that to move the beam back and forth across the room.
Check out the Propeller Wiki·and contribute if you can.
It's not that you "can't", but that "your not allowed to", per most building codes. Anything that looks like it's part of the ceiling, or attached to it, is "supposed" to be supported on it's own. The ceiling grid should hold the ceiling, and nothing more.
John R.
Click here to see my Nomad Build Log
Just a thought.
Take a serious look at http://www.8020.net/ - give them a ring and ask if they have any motor attachment ideas for conveyance systems. With an X/Y gantry you'll have far more flexibility if the desk arrangement changes, or if you choose to use the airborne drop-off in a different capacity than currently envisioned.
- Ken
Although unaware of this beforehand, I concur, the ceiling mounted system will inevitably clash with building code, or a similar "red tape" issue.
So, I was thinking of using either a helium balloon system to retrieve & deploy documents - something that would hover about six inches below the sprinklers. At my stage of robotics, this seems doable, but incredibly difficult and seemingly unreasonable to pull off. Incorporating a set height from the ceiling while payload changes take place seems like an enormously difficult issue to deal with.
A wall mounted system has also been in consideration.
There is one more factor worthy of consideration: in this 9' 6" ceiling height room, there are two floor to ceiling columns in the center section of the floor plan. These columns could be either a hindrance or a boon to a wall & column only mounted system (see revised image below).
I've also considered a tube system utilizing containers and compressed air to transport doc's. It's somewhat complex and looks like a large polymer octopus on steroids - also has many unknowns to be resolved - perhaps another formidable challenge.
If I go with a floor traveling vehicle of some sort, I would want to make it a really good one but that seems somewhat blase compared to some other, more interesting systems. I have an unlimited budget for this, so, throw more great ideas at me.
Thanks again,
Scope
You might research track lighting component Mfrs for ideas on the actual rails for your system. Many of them have systems that will deliver low voltage (12V DC) to the track pieces which would solve the problem of powering your "car(s)". They've already done the engineering for the rails (straight and curved), electrical connections between rails, AC to DC electronics, etc.
Duffer
Cheap, pre-drilled and mostly available in the electrical department at Lowes or Home Depot. The nice thing about it is that it is designed to hang from all-thread.
http://store.eberliron.com/products/unistrut_parts/unistrut_trolley_assemblies sells trolley's for them.
The XY idea is perfect but if those are wireways coming up out of the top of the island workstations, that will be a bit harder.
OR, use the island as the center of a radial system. You could also do a set of channels that have handoff points; right; left; center, back of the room.
Cool Project!
Signature space for rent!
Send $1 to CannibalRobotics.com.
I think it would look cool to have a bungee type of drop that, when fully descended to the stopping point, would then free fall about 1/2 inch onto an electromagnetic joining system with alignment correction. The retrieval process would involve a similar, opposite effect where the bungee tension would build up to a point where, when the electromagnetic holding system was released, the container would leap up, then connect onto the rail-supported carrier in a like manner.
Or maybe I could just use a crazy-fast winch to raise and lower the document container - so many possibilities, so little time . . . ah . . .
***ing may involve a presumed element of potential failure - we embark only to succeed.
And, thanks very much for the support. [noparse]:)[/noparse]
Yoda was mistaken.
Our product was used to make a frame for this robot called the ABB FlexPicker. It's a robot who's designer must have been on drugs at the time, but it works very, very well. I dunno what made me think of it but:
If you use monofilament on three driven spools mounted to three walls..... maybe two corners and a wall? Three spools, three lines at 120 degrees to a round plate to level the load and balance the fixture. Off the bottom of the plate is your controller, battery and a gripper.
I'd give you X, Y and Z. You COULD use Parallax's continuous rotation servos although it'd be slow. I'm thinking more three small brushless outrunners with speed controls and you send them PWM for control. [noparse]:)[/noparse]
Hmmm, actually you'd need three conductor wire for the monofilament and a slip ring... yuck...... or IR communication and a master slave system.... Hmmm
OK, I'm just dreaming.
My head is pasming!
The follow up by erco closes the design issue in my view. This gives 3D movement, minimal installation, and some challenging programming!
Post Edited (Capt.Kerry) : 2/3/2010 9:44:07 AM GMT
I would still suggest using model RR parts for several reasons. The parts can be easily obtained, the cost is reasonable, and there are lots of possibilities to add to the system and automate it. It also lends itself to being mounted suspended from the ceiling or to the back of the desks on posts.
If you really want to build it from scratch then a simple monorail system could be built using plywood and thin conductive strips of copper, brass, or aluminum.
Ron aka sailman58
My head is pasming!
Rail Systems at B&H
www.bhphotovideo.com/c/buy/Rail-Systems/ci/1348/N/4294550788
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
erco, thanks for that link!!! There's a very high chance that the cable coming out of the side of that camera was made by the cable assembly department here at work. We occasionally make cable assemblies for that camera maker and have made several for that camera model. Most of those cameras end up in helicopters.
Andrew Williams
WBA Consulting
