$3,500 power cord!
W9GFO
www.highendcable.co.uk/Nordost%20VALHALLA%20Power.htm
So you spend $3,500 for a power cord for your hi end audio system then realize that on the other side of your outlet is Romex. (insert face-palm icon here)
Un-freaking believable!
The Simple Servo Tester, a kit from Gadget Gangster.
KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
I use 18 AWG zip cord for my speakers and I get great sound and its cheap .
and "those power conditioners" Meh most AV gear goes in to a SMPS anyways .. so what if the wall is off by 3 V or a few Hz .
mind you I Use high end TrippLite Isobars on all my gear . but its not for better sound .. its for the naasy spikes Edison puts on our line back In CA..
I love being a E tech . you can walk in to a B Buy and cut through the junk they try to sell you ..
yet I make my own cables o for everything I can . I use RG6 with snap and seal conns ..
BTW if you want to annoy a audiophile . you can tell them that technically every solder joint in there gear is a point contact diode that could add some minute amount of rectification that can resort in distortion .
now us RF guys We NEED high end stuff when working with 8GHz and the like .
audio is darn near "DC " to me
KG6LSE Peter
LOL
www.youtube.com/watch?v=xs1aUws0Lrs&NR=1
There's nothing like inflicting brute force on ignorance...
And no, it doesn't matter what kind of power cable he uses if there's a switching mode PSU in his equipment.
Tubes are nice... Very linear amplification, which means very little distortion.
Unfortunately, they have two small disadvantages; lifespan and impedance.
It's easy enough to replace the tubes, so it doesn't count as a major setback, but there's that impedance problem.
In old designs I believe they used a transformer or something on thee final stage, before the speaker, to get around that, but modern designs have solved that.
I don't believe that an audiofool would be able to tell the difference between a solid state and a tube amp in a proper blind test, though. So they're mostly for aesthetics, really.
(That, and showing off how much money you're willing to spend on audio equipment)
I use cheap 'speaker cables' (in that semi-transparent insulation) mostly because people expect to see cable like that(saves a lot of explanation).
What matters most is the thickness of the cable. Sure, on the short runs from my amp to my main speakers (it's about 1 - 1.5meters) I can use practically anything, but on the rear speakers(awaiting reconnection and have done so since I moved two years ago) the lengths are getting so long that the resistance will actually add up to something, at least if I use the thinnest cables.
Don't visit my new website...
What fools!
Signature space for rent!
Send $1 to CannibalRobotics.com.
Hospital grade outlets will not help. They only make it impossible to get a spark from the outlet to anything around(makes a difference if you have oxygen tanks around but not audio equipment). For most people if you are worried about this rap the outlet in electrical tape before putting in the wall.
Isolated ground will improve sound quality if you pipe everything. The reason for this is AM radio stations can be picked up by the ground wire and play out as fantom sound over your speakers. Conduit will act as a fairdays cage blocking the radio signals preventing it from getting to your isolated ground wire.
Other then that as long as your electrician follows the Canadian Electrical Code(Use 12 AWG instead of 14AWG for 20A circuits) you will not have any problems from the mains.
The reason high end audio cables are directional is because of the shield. When made properly the shield should be grounded at the side of your amp only. If reversed the shield is useless and as a result you may here phantom AM broadcasts. Unshielded cables obviously do not mater what direction they go and cheap shielded cables are often grounded at both ends which is actually worse then not having a shield.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
It makes the power your system depends on arrive quicker.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Wow. I did miss that.
Rich H
I exited the conversation rather quickly after that...
DJ
BTW - in the early 80's, the hot thing along with Monster Cable was the "audio brick"; a specially made composite that when placed on speaker cabinets was supposed to dampen unwanted resonances. That slighty made *some* sense, but when people began to place the brick on top of their stereo components and claim sonic improvement, I began to think that they had something awry in their cranial nether-regions.
