MLX90614 IR temperature sensor Can`t get any contact with the sensor
When the power to the sensor is turned on the propeller stops.
As you can see in the code, I have a counter to see it`s running.
I first tried with 5v, but now it`s running on a propeller pin.
The signal is connected directly and the reset is connected via a 1k resistor.
I have tried adress $5A and $00.
Any idea?
Any idea?
CON
_clkmode = xtal1 + pll8x
_xinfreq = 10_000_000
lcdtx = 10
mlxsig = 15
mlxpower = 9
mlxreset = 8
VAR
long irtemp
long tester
long Stack[noparse][[/noparse]20]
OBJ
bs2 : "bs2_functions"
serial : "Extended_FDSerial"
mlx : "MLX90614"
PUB start
mlx.start(mlxsig,mlxreset,9600)
bs2.start(21,22)
cognew(Lcd, @Stack)
tester := 1
dira[noparse][[/noparse]mlxpower]~~
outa[noparse][[/noparse]mlxpower] := 1
repeat
irtemp := mlx.GetTempC(0)
waitcnt(clkfreq>>1+cnt)
tester := tester + 1
if tester == 1000000
tester := 1
PUB Lcd
serial.start(20,lcdtx,1,38400)
serial.tx(13)
serial.tx(13)
Serial.str(String("ac01")) 'clear screen
bs2.pause(100)
serial.tx(13)
bs2.pause(100)
serial.tx(13)
Serial.str(String("ac80")) 'home
bs2.pause(100)
serial.tx(13)
Serial.str(String("ac0c")) 'cursor off
bs2.pause(100)
serial.tx(13)
Serial.str(String("adLoading")) 'print loading
serial.tx(13)
bs2.pause(1000)
Serial.str(String("ac01")) 'return home
bs2.pause(100)
serial.tx(13)
repeat
serial.tx(13)
Serial.str(String("ad")) '1.line
serial.dec(irtemp)
serial.tx(13)
Serial.str(String("acc0"))
serial.tx(13)
Serial.str(String("ad")) '2.line
serial.dec(tester)
serial.tx(13)
My guess is that the mlx.GetTempC never returns. Maybe you should power on the MLX before calling the mlx.start. Maybe start is doing some initialization of the MLX.
