Saving to EEPROM
I was using the search function but having problems·finding good examples.· Can anyone point me towards a document that might explain this function better.
I am trying to save 4 different strings to the EEPROM where they can be accessed after a power failure.· I know I can't write them very often, as they will only probably change once a year or so.
I am using a I2C object already to read from a real time clock IC.· I have been looking at an example that Terry from Hitt Consulting put together, but having problems understanding exactly what is going on.
If anyone knows of a good tutorial, I would greatly appreciate it.· Thanks!
Id
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
PUB SaveToEEPROM | pos, addr, temp pos:=2 '<-change 1/2/3/4 for different Memory Positions addr:=32768 + (pos-1) * 12288 ' Start the I2C (EEPROM) Object I2C.Init(28, 29, $A0) ' Use Propeller Demo Board EEPROM I2C.i2cStart IF addr < 65536 I2C.i2cWrite($A0, 8) ELSE I2C.i2cWrite($A2, 8) I2C.i2cWrite((addr / 256), 8) I2C.i2cWrite((addr // 256), 8) REPEAT temp FROM 0 TO MaxChar I2C.i2cWrite(tempStr[noparse][[/noparse]temp], 8) tempStr[noparse][[/noparse]temp]:=tempStr[noparse][[/noparse]temp] ^ 255 IF (addr & $FF) == $FF I2C.i2cStop WAITCNT(400000 + cnt) ' 5mSec I2C.i2cStart IF (addr+1) < 65536 I2C.i2cWrite($A0, 8) ELSE I2C.i2cWrite($A2, 8) I2C.i2cWrite(((addr+1) / 256), 8) I2C.i2cWrite(((addr+1) // 256), 8) addr+=1 I2C.i2cStop WAITCNT(400000 + cnt) ' 5mSec REPEAT temp FROM 0 TO MaxChar tempStr[noparse][[/noparse]temp]:=tempStr[noparse][[/noparse]temp] ^ 255 PUB LoadFromEEPROM | pos, addr, temp pos:=2 '<-change 1/2/3/4 for different Memory Positions addr:=32768 + (pos-1) * 12288 ' Start the I2C (EEPROM) Object I2C.Init(28, 29, $A0) ' Use Propeller Demo Board EEPROM I2C.i2cStart IF addr < 65536 I2C.i2cWrite($A0, 8) ELSE I2C.i2cWrite($A2, 8) I2C.i2cWrite(addr / 256, 8) I2C.i2cWrite(addr // 256, 8) I2C.i2cStart I2C.i2cWrite($A1, 8) REPEAT temp FROM 0 TO MaxChar tempStr2[noparse][[/noparse]temp]:=I2C.i2cRead(0, 8) I2C.i2cStop
