Can you help me
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
LEDPin1 = 0
LEDPin2 = 18
SwitchPin = 23
Var
long LastSwitchChange
long RateThreshold
long LastCNTValue
long ResultCNT
byte SwitchStatus
Pub start
Dira[noparse][[/noparse]LEDPin1]~~
Dira[noparse][[/noparse]LEDPin2]~~
Dira[noparse][[/noparse]SwitchPin]~
RateThreshold := 100_000_000
LastCNTValue := cnt
repeat
ResultCNT := cnt - LastCNTValue
if Ina[noparse][[/noparse]SwitchPin] <> SwitchStatus 'is the state of the switch different from the last time it changed?
LastCNTValue := cnt 'lets record this time
SwitchStatus := Ina[noparse][[/noparse]SwitchPin] 'store this as the current switch status
if ResultCNT > RateThreshold 'we have gone over our threshold with no change in the SwitchStatus
'this means either the switch was held down or not pressed
outa[noparse][[/noparse]LEDPin1]~
If SwitchStatus == 1 'Switch was held
outa[noparse][[/noparse]LEDPin2]~~
else 'switch was not pressed
else 'the switch is changing faster than the threshold rate
outa[noparse][[/noparse]LEDPin1]~~
'ADD THIS TO THE PROGRAM UP THERE..........
PUB Turn
dira[noparse][[/noparse]4..9] := %111111
outa[noparse][[/noparse]4..9] := %111111
waitcnt(clkfreq/4 + cnt)
outa[noparse][[/noparse]4..9] := %011111
outa[noparse][[/noparse]4..9] := %001111
outa[noparse][[/noparse]4..9] := %000111
outa[noparse][[/noparse]4..9] := %000011
outa[noparse][[/noparse]4..9] := %000001
outa[noparse][[/noparse]4..9] := %000000
PUB Down
What I want is, To hold down (pin23 switch) and outa [noparse][[/noparse]4..9] led's will come on. That same (pin23 switch) if I were to hit it on and off, on and off, on and off- It will make outa [noparse][[/noparse]4..9] (it will go 4 5 6 7 8 9).
That's all.......................
