Sensor to read LED flash on back of a camera
WHall
I recently purchased the Board of Education and am working through the first few lessons in the What's a Microcontroller? book. Ultimately, I'd like to build a mechanism that would take pictures for a high altitude balloon payload I'm working on. I'm using an intervalometer (CHDK) to script the Canon A570 camera to take a series of timed images. I'd also like to use a sensor (taped to the camera) to read the flash of a white LED (on the back of the camera, next to the optical viewfinder) into the Basic Stamp 2, which would pulse, in turn, a servo to reorient the camera. I've searched the forums and the Parallax site, but I'm still confused (sorry!) as to what sensor, if any, might see the flash that would indicate a picture has been snapped. I'm just getting started - a fact that will probably not surprise anyone who's read this post - but any thoughts on what sensor to use would be very much appreciated.
http://forums.parallax.com/showthread.php?p=861003
but I second every one else s idea of the LED .
Also a small solar cell could be used too .. the shack has a small one you can cut (break) in to smaller peaces to use as a over-sized photocell.
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
I captured the output of a small existing·LED optically by glueing a photo transistor over it and had it·fire a transistors base·to switch·voltage to·LEDs both in front of the camera and in front of the camera operator (to replace the one I covered up).
It worked great.
I would think that this method could easily trigger a stamp as well.
jeff
