RH sensor
Hello,
I have the relative humidity sensor that Parallax sells. I was wondering if it would be possible to use it to measure moisture in masonary. My research shows that most masonary moisture sensors use capacitance change just like the RH sensor does. I want to measure moisture content in masonary walls nondestructivily using the prop and then logging the data. Any suggestions would be appreciated. This is for my students at a university.
Curtis
Curtis
