parseInt - help!
Good morning from Down Under.
I am sending myself completely insane over something that should probably be quite easy. I am simply trying to validate an NMEA stream by calculating a checksum and then comparing it to what the compass sends out. The problem I have is that I don't know how to convert the two byte hex code to an integer. i.e. here is my sentence;
$C264.4P-0.8R0.9T25.2*08
I have calculated the checksum using;
comp_chsum = (byte)InBuffer.charAt(comp_start+1);
for (m = comp_start + 2; m < comp_end; m++)
comp_chsum = comp_chsum ^ (byte)InBuffer.charAt(m);
where;
comp_start is the position of the '$" at the start of the sentence
comp_end is the position of the '*' before the two digit checksum
However I can't convert the hex *08 to an integer.
I have tried;
CompChk.append(InBuffer.charAt(comp_end+1));
CompChk.append(InBuffer.charAt(comp_end+2));
comp_in_chsum = Integer.parseInt(CompChk.toString(), 16);
Even though the Javelin manual suggests that you can use an "optional radiix" for the parseInt, the compiler doesn't like it. I get the message;
Error:No match was found for method "parseInt(java.lang.String,int)"
This would suggest that you can't have an optional Radiix.
Any ideas on how to convert the 08 to an integer???
Istha
The robot is going to lose. Not by much. But when the final score is tallied, flesh and blood will beat the damn monster.
Adam Smith
where;
I have tried;
Istha
Adam Smith
int low = InBuffer.charAt(comp_end+2) - '0';
if (high > 9) high -= 7;
if (low > 9) low -=7;
int checksum = ((high << 4) & 0xF0) | (low & 0x0F);
regards peter
I wouldn't have worked that out in ten years.
Peter, you're a legend.
Thank's,
I
Adam Smith
