MAX186 ADC and Propeller
I'm thinking about moving my bs2px controllers (redesigning) around a propeller using one of the proto boards with 3/5 volt regs. Just getting into the Propeller, I'd like to know how difficult it would be to use the MAX186 ADC (12bit/8channel) with it. Reason is that aI have a bunch in use, and would not have to swap em out for something else.
Any ideas or proposed connections appreciated.
You don't need them for Prop outputs that go to input-only 5V pins, but you also need them for bi-directional pins. Hope this helps.
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
