Connecting a Thyristor to a BS2PX?
I'm building a kiln controller to replace a bespoke one I had purchased which has stopped working. I'm using a BS2PX and A BOE. I have a DS1302 and a DS2760 hooked up and running for time and temperature, now I need to be able to switch the power to the kiln on and off. The kiln is 240 V AC and as much as 30 A. The old kiln controller used a Thyristor for the switching (see attached images).
I know little about electronic circuits, how should I hook up this thyristor to be switched by the stamp? The old one had an opto-isolator between the thyristor and the controller, do I need that with the stamp? The old opto-isolator was an MOC3043. Could I use an MOC3022 (I have a source for those)? What else is needed in the circuit to hook it up?
Lance
Lance
Have you researched using a Triac? There are a number of options available, and with the use of the Opto chip, you could turn it on and off with relative ease. Most have a high voltage range and good current rating; I'm using a 600V 16A to control some stuff in my house and have a opto chip to protect the I/O; works like a charm.
If you do a Google search you can get a listing for triacs that can switch that type of load. Digikey has a part that looks like it might be a place to start. Here is a link for your review.
DigiKey:
http://parts.digikey.com/1/parts/992996-alternistor-600v-30a-isola-to220-q6030lh5.html
Respectfully,
Joshua Donelson
www.parallax.com
Lance
You don't say whether the heating is on-off or proportional, but a simpler solution for you is a good solid state relay which will incorporate all the gating and opto-isolation within one module. Pick a 240v 30 A (or greater) for the load side and apply 5 volts from the Stamp to the opto in the relay.
Cheers,
Tom Sisk
http://www.siskconsult.com
