interfacing matlab with basic stamp
hi all,
i am doing research to control a movement of mobile robot by using brain signal. i was used matlab software to processing the brain signal and do the neural network. the neural network will generated output data for every movements task.
i have a problem to interfacing the bs2 with basic stamp. please help anyone..
regards,,,
regards,,,
However, if the computer running Matlab can provide a serial output, a Stamp can read that data and act on it.
Tom Sisk
http://www.siskconsult.com
actually, i just used bs2 to control 2 servo motor, my output from matlab just to configure the brain signal which one for output task, the task is forward, stop, left and right.
i already train all data in neural network. and the output can be found when i run singlevalue command in matlab by using better net from neural network. i want to do some offline experiment and i have a problem to communicate the matlab with bs2. pls help.
Post Edited (missingcameo) : 1/27/2010 6:45:43 PM GMT
- Stephen
