GPS Update Rate
Is there a GPS module which updates more frequent than 1 Hz?
I would like to build a device to record various parameters(acceleration, lean angle, speed, etc) when mounted on a motorcycle on a race track and then map these values to the track itself. With an update rate of only 1 Hz that would mean a GPS value only every 150 feet if traveling at around 100 mph and speed typically go as high as 160 mph.
www.sanav.com/gps_engine_board/FV-M8.htm
You can change the baud rate and the uptade of the single strings up to 5Hz. Documentation is poor, but I was able to set baud rate ad update rate, playing with resets during the setup. I have a test demo updating up to 5Hz and saving to a SD, using existing code from obex. If you are interested in this GPS model I can upload the code, even if it is a work in progress, poorly commented.
Massimo
Thanks for the info Massimo
Robert
Powered by enthusiasm
http://www.sparkfun.com/commerce/product_info.php?products_id=9060
Sylvie369, you are probably right, It seems that more accurate modules are available with higher update rates but the cost gets much higher. A combination of techniques to calculate position may be the best method.
Robert
You won't get an accuracy of 1 to 2 feet out of GPS, regardless of your update rate. Even at 1000 Hz, you'll still be limited to about +/- 30ft due to day-to-day drift, reading-to-reading noise, etc.
Dave
I assume that the GPS units sold for running have similar accuracies. If thats true then a 30 foot error would mean that instantaneous speed calculations are not even close to being accurate.
Does the accuracy number mean that the difference between two consecutive readings separated by 1 second in a GPS module with a 1 Hz update rate may vary by up to the specified number(2.5m for example) or is the interval between reading longer or does it have to do with the difference between two reading separated by a specified distance regardless of time interval.
Robert
The accuracy SHOULD be the difference between where you really are vs. what the GPS tells you. The accuracy is typically around 30 ft or so. Between consecutive readings, or even readings over a few minutes, the difference will be less (maybe 5 to 10 feet over several readings), and will depend on signal strength, velocity, acceleration, etc.
Hope that helps,
Dave
Robert
Jim
The best thing to do is use a kalman filter to process the data. GPS is great over time, where Accels and Gyros are great for small distances. Combining the three together (maybe even with Magnetometers) will give you a better understanding of what is happening.
Bill
