RFID vs. Inductors, who wins?
I have been interfacing RFIDs with propellers for a while now, and I never had any problems. I recently switched some voltage regulators from linear to switching. Ever since then I have had problems with the RFIDs. I found that the setup I was using caused the fob keys to not work at all, and the card keys to work at a very limited range.
While my RFID reader was fairly close to the switching regulators (2cm or so) I placed a layer of grounded shielding between my PCB (with the inductors/regulators) and the RFID.
For whatever reason I thought I would try a second layer of grounded shielding (not thinking it would actually change anything). Now, the fob key works at about 1cm away, and the card key at about 3cm. Originally they worked at about 9cm and 13cm respectively. I really need the fob to work at a minimum of 3.5cm (which is already pushing it for distance).
Any ideas as to what is happening? I assume it is interference from the switching regulators and inductors, but how can I quell the escaping EMI?
I must keep the switching regulators due to power consumption issues, but the RFID is absolutely necessary. The location of the RFID can't move more than 1cm in any direction due to packaging. The only solution I can think of is more layers of shielding. Please someone help. I am not clear why a second layer of shielding is increasing performance.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
Some of my objects:
That might help.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134·
Some of my objects:
Leon
Amateur radio callsign: G1HSM
I am kind of limited because I need an adjustable regulator that can put out an amp or more.
Some of my objects:
Just as a foundation for a further explanation, do you understand how RFID works at the electrical and RF level?
--jc
Leon
An education would be nice.
Some of my objects:
Once the controller detects the RFID chip is in the field, it switches to generating a 125Khz carrier. This both powers the RFID chip and causes it to start clocking out data. The data Frequency Shift Keying (FSK) modulated. A '1' is approximately 16Khz, a '0' is approximately 12Khz. A low pass filter allows the 16Khz and 12Khz FSK data into the circuit that starts assembling the sequence of 1's and 0's into a data stream (I've simplified this a bit, as it's not really relevant).
The data stream then gets some post-processing in the RFID reader, or it passes the raw data up to the controller processor (the Propeller, in your cause).
What happens is when you have another 125Khz (or nearby frequency) you cause interference with the RFID reader and the RFID chip. The 125Khz carrier from the RFID and the interfering source mix, and don't produce a frequency the RFID chip can reliably respond to. It can also overwhelm the filters that let the 16Khz and 12Khz through. This results in reduced read range, read errors, etc.
A large chunk of metal (such as a shield) may reduce the interference, but it can also de-tune the RFID antenna. This causes the antenna not to be responsive at the designed frequency, so the read range is reduced.
Your best option is to change the SMPS to a frequency that is not close to the 125Khz and also not a multiple of it. 250Khz wouldn't be as bad as 125Khz, but it wouldn't be good. Be careful of shielding the switcher. Like the RFID circuit, if your shielding is done improperly, you can affect the characteristics of the SMPS and it won't perform to expectations (this is primarily around the inductor. Adding shielding will effectively change the inductor value).
--jc
I removed the shielding, and suddenly all problems are solved. Hopefully the software part of it (my forte -- it's never been hardware) is also solved. I guess we will find out with testing.
Thanks for the education.
Some of my objects:
