Resistor Issue
For my holiday lights animator, I built a circuit similar to this (see zero cross) only the 15K ohm resistors are 22K ohm 3/4 watt. The second pic I took with my phone (its blurry) shows a picture of the SMT board I made for it. The 22K ohm resistors get hot. When I feel them with my·pinkey finger knuckle it burns it. When I feel it·with the base of my pinkey·it·only feels warm. Guess the knuckle is more sensitive. When·I remove power it·almost immediately cools off.··There is:
60.2 volts across the first 22K ohm resistor·········· V = 60.2
the first 22K ohm resistor measures 22.04K ohms··· R = 22.04K
P = V^2 / R = 166.2mW
There is no where near the 750mW limit so why is it so hot? Should I up the wattage or just let it go?
bmp
663K
*Peter*
Of course this comes from the UK where it is 240 Volts.
Style and grace : Nil point
Back when I were a lad ... 1 Watt of dissipation would be given a wholesome area to radiate it from, much as Peter was pointing to, nowerdays the miniturisation has left everything with no surface area. It might be able to withstand 1 Watt, without vapourizing, but nature still needs that Watt to wander off.
(and electrolytic caps are too small for their own good ...)
Digital probing is ok until you find that your fingerprints have been left behind, and there's a burning flesh aroama, again.
