X Positioner
Hey folks, been away from the forums for quite some time and have a new project I am working on.
I'm looking for an X only positioner pre-built with a motor. I can create the driver circuitry and programming. So far what I've found after spending 2 hours on the internet is a lot of stuff that seems overpriced or overkill.
I am only needing to move a load of less than 1 pound about 30-40" up and down, but it has to be "somewhat" precise and repeatable. I'm thinking something along the lines of a printhead carriage. If it weren't for the length I need, I could probably cobble up something from an old dot-matrix printer, but ultimately this may wind up being a commercial solution, so that would only really be good for a prototype.
There has to be something simpler out there. Anybody have any suggestions of places to look? My eyeballs are falling out searching Google.
Jeff
Jeff
PG
- Stephen
Garage door opener - too big. Entire thing must fit inside a cabinet that is 20.5" by 40", 11" deep. Interesting thought though.
Precision, price-range: Well, it won't sound too technical, but I need to be able to select from 60 items that are spaced at 1/4" intervals, so not real precision. Price range, well as cheap as possible of course. $700 is too much. I'm thinking should be somewhere around $250 cost.
One thing I re-discovered last night was a company called 80/20 (8020.net). I have known about them for a number of years but didn't realize that I could probably construct a slide with their products, add a stepper motor, pulley and belt drive, and a homing sensor. All for a pretty reasonable price.
It's just that I'm not nearly mechanical as I am electronics and software, and the thought of constructing this intimidated me a bit until I started to dig deeper.
If I decide to go the 8020 route, I will post some pictures of what I come up with. Or not, if someone else comes up with a compelling alternative.
Yes, I have a friend here locally that has a machine shop. I'm feeling brave. I may attempt this first before enlisting his help.
Jeff
- Stephen
