PIR sensors in fire accidents
I am doing my real time project using PIR sensor(#555-28027).My project is based on indoor resident location.
In case of fire accidents in an indoor location,where in this situation we expect heavy smoke,fire,high temperature.My query about this sensor is can this sensor detect· the motion of human in above mentioned consequences.
Powered by enthusiasm
I'm going to suggest that you'll have some problems with this. I did some work with a company on a "zero force" sensing system to try and keep track of people. The system worked great in most cases. It was a total failure at an installation at an air port hanger. What made this one application different? The ambient temperature turned about to be very close to 98.6. The PIR stuff couldn't see a thing. We verified this by turning the heat WAY up in the test area, and we were able to duplicate the results.
If the fire is "hot enough", maybe the humans will appear cold enough to be seen, but I'm guessing not. I'm not sure how you'd really test this, other than with a real live fire department (or your soon to be ex-friends house). Even using something like a bonfire wouldn't be a good test, as while you could get a hot background, you don't have the same "overwhelming" of the ir sensors that you would have in a fire.
That said, there may be some hope, some departments do use an IR camera to help with search and recovery. This does see through the smoke, and people do appear "colder" than the surrounding blaze, at least in some cases.
John R.
Click here to see my Nomad Build Log
