Tri Axis accelerometer (detection of G-force changes in X and Y axis)
I am now doing on Tri- axis accelerometer, I met a problem when I try to program the accelerometer to work in the way when the G-FORCE of X n Y axis changes, it will alert the user. But when i transfer the code to the BS2 chipi have problem that is one of the axis show that it already have G-FORCE change and it automatic alert the user (it happen when the accelerometer is on the table.)
and i dont understand how to set a threshold value for the G-FORCE lik --> G-Force > ***???
Post Edited (Jazie) : 1/24/2010 4:08:00 PM GMT
2) Attach your code to your next message. Use the "Post Reply" button instead of the Quick Reply box and use the Attachment Manager to upload the source file.
3) Include a detailed description of how you have the accelerometer wired to your BS2.
I had posted the stuff you need in the first message. (p.s this is the first time i use a forum =X )
the accelerometer is wired as stated by the data sheet.
thank alot.
