PollRun not transfering information
hello,
i am using a BS2p24 micro in a project of mine.
In this program i am using
POLLIN 2, 1
POLLRUN 1
POLLMODE 4
However when poll run is activated and runs the program in slot one, the information from a variable in slot 0
is not carried through to the program in slot 1.
does any one have any idea on why the program is doing this and is there a solution?
any help will be greatly appreciated. thanks.
-cruzer
POLLIN 2, 1
POLLRUN 1
POLLMODE 4
-cruzer
The Stamp Editor's compiler allocates variables in the order they're declared in the program according to their sizes. I believe words come first, then bytes, then nibbles, then individual bits. If you have extra variables, that can throw things off.
There's a good explanation of multi-slot programming in one of the Nuts and Volts Columns (maybe #85). Look under the "Resources" tab on the main Parallax webpage. You'll find the link to the Nuts and Volts Columns index.
