Announcing SerPlug: A $9.95 Serial Plug programmer kit for the Propeller (build
Bill Henning
SerPlug is born!
A Brief History:
Over the years I have seen many questions about serial programming circuits for the Propeller. Personally, I've tried the two and three transistor circuits - unfortunately I found that they did not work with all USB to Serial cables. That's why I designed a MAX3232 based RS232 programming circuit for my Mem+ board. At the same time, I also laid out (in Eagle, in case any one is curious) a stand alone version; however I assumed that most people who got a Morpheus board would get a Mem+, or would already have a Propeller Plug.
Late last year, I showed a preliminary layout to Sapieha ... and he kindly offered to make a nicer layout for me. He was right, his layout is nicer than mine was.
Off it went to prototype production... and today I got the prototypes.
I am happy to announce that the SerPlug prototype PCB's work perfectly!
- SerPlug has a 3 pin jumper for choosing RTS or DTR as the RESET signal
- SerPlug has a RSTEN jumper, which if removed, stops the Propeller from being reset.
SerPlug will be shipping in approximately three weeks, which is when I will get my production shipment - however you are welcome to place a pre-order now.
SerPlug's 5 pin header is PropPlug compatible, with the addition of a fifth pin that supplies +3.3V to SerPlug. If you are programming a board that only has a 4 pin connector, simply run +3.3V to the fifth position.
Of course, you can also use SerPlug to add additional RS232 ports to your Propeller board - just wire two Propeller pins to pins 3&4 of the five pin connector, and connect GND and Vcc. You can also run the board at 5V for compatibility with 5V microcontrollers!
My intention is to price the kit at (or below) what the parts plus PCB would cost - approximately ($2.50 + (the single quantity price for the parts used based on DigiKey's current pricing))
I got up early this morning, and crunched some numbers... so I have figured out the pricing.
SerPlug will cost $9.95 USD + s/h for qty.1
SerPlug page at Mikronauts.com: mikronauts.com/products/serplug/
Forum Special:
- one SerPlug kit for $9.50 USD + s/h
- two SerPlug kits for $18 USD + s/h (regular price $19)
- four SerPlug kits for $35 USD + s/h (regular price $37)
- larger quantities will be available, ask for a quote on the quantity you need
To pre-order your SerPlugs, send me an email with how many you want, and your snail mail address so I can figure out the shipping and handling.
Rough estimate for Continental US s/h is:
1 SerPlug kit: $3.50 USD (Light Packet Air)
2-4 SerPlug kits: $8.00 USD (Small Packet Air, may fit more than 4, I have to weigh the new kit)
Shipping to Canada should be a bit less, and shipping to Europe will be more expensive.
For more, or destinations outside of the Continental US, I will have to manually look up the shipping.
I am attaching three shots of SerPlug packed into one image:
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Post Edited (Bill Henning) : 4/9/2010 6:05:28 PM GMT
A Brief History:
Forum Special:
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
I've updated the first post with pricing information... I am making SerPlug VERY affordable!
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
I am deliberately keeping the price as low as possible to lower the "barrier to entry" for the Propeller.
mikronauts.com/products/serplug/ is the SerPlug page.
Do you guys think I should offer an assembled and tested version?
I'd probably charge $14.95 USD + s/h for an assembled and tested SerPlug, with $1 off for forum members.
See mikronauts.com/products/new-propeller-budget-starter-kit/ for details.
- I've decided to sell assembled and tested versions of SerPlug for $14.95 USD + s/h, with $1 off to forum members
(with Small Packet Air shipping to continenta USA, that makes it $22.95 USD shipped to the continental US, or $21.95 for forum members)
- the pre-order special "Propeller Budget Starter Kit" is only $42.95 USD to the continental US INCLUDING Small Packet Air shipping
see mikronauts.com/products/new-propeller-budget-starter-kit/ for contents of the kit
(note after the pre-order period that ends Feb.10 this kit price will increase by $5 USD)
- SerPlug works very well with a breadboard; if you solder a male header instead of female it plugs right in! I will post a photo later.
Post Edited (Bill Henning) : 1/27/2010 5:45:03 PM GMT
You need bigger and less obstructed pictures of your products. Why did you Mikronauts.com across the pictures like an ad on eBay?
James Ronald
My Robots
Thanks for the feedback! I will change to individual pictures with a translucent logo.
I was in a hurry, I had to finish figuring out why uSD was not working on one of my boards (when the full sized SD worked fine on the same board) before sending it in for a production run. I have now removed the uSD connector, found the problem, and the board is fixed and going in for a production run tomorrow. (I had three prototype PCB's come in on the same day - SerPlug, the uSD problem board, and mctrivia's interface for his modules to Morpheus - they all came in on Thursday last week in one shipment)
I will now have time to do nicer product pictures (separate ones, with almost totally transparent logo, so I can use them on Ebay too).
Best Regards,
Bill
Post Edited (Bill Henning) : 1/28/2010 5:29:14 AM GMT
They work perfectly [noparse]:)[/noparse]
Kits are now in stock and ready to be mailed to buyers [noparse]:)[/noparse]
SerPlug is $9.95 USD + s/h for qty.1
You can see photo's of assembled SerPlugs at the link above, and also in the first post of this thread.
Forum Special:
To order your SerPlugs, send me an at 'mikronauts at-symbol dot com' with your name, forum handle, paypal email address, and snail mail address, and I will send you a PayPal invoice.
Postal shipping and handling for the Continental US is:
For destinations outside of Canada and the Continental US, I will have to manually look up the shipping.
The SerPlug built into PropCade works with ViewPort at 1Mbps with the Parallax USB to Serial adapter - should work with any other 1Mbps capable USB to serial converters that ViewPort supports.
I thought I'd see if SerPlug would also work at 1Mbps.
I am happy to report that SerPlug runs fine at 1Mbps with ViewPort! I tested it with a SerPlug plugged into Morpheus, and boy was I happy!
Note: This worked with the SP3232's I tested, but did NOT work with the MAX3232 I tested - nevertheless, it is a great result [noparse]:)[/noparse]
- streaming video
- high sampling rates
- high update rates
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
I've finally had time to finish the "SerPlug Build Manual" - it is available for downloading from the "Downloads" page of Mikronauts.com
Mikronauts.com/downloads/
On your site the image posted above says the following under it, "(RIGHT-CLICK and choose “View Image” to see a larger photo)" What browser supports that function? I can't see a bigger picture using IE8. Just an FYI.
Parallax Engineering
It function on FireFox -Right click - Show picture.
Regards
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
