motor help
I know very little about motors. I need to find a light weight low power motor that I can spin at exactly 100Hz and preferably for as cheap as possible. I have a prop on board so I can PWM the power to it or any other control method to control its speed. My problem is I have no clue where to start looking to buy a motor that fits my requirements.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
Post Edited (mctrivia) : 1/22/2010 6:29:11 AM GMT
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
W9GFO I did not even think about servos. Small ones are not that expensive though they are usually pretty bulky. I can't find any though that can do 60 deg in 0.00167sec(100Hz)
Post Edited (mctrivia) : 1/22/2010 6:08:07 AM GMT
I'll look and see if I can find any that have those specs.
Rich H
I did find lots of servos with 60 deg speeds of .1 sec or less but I did not find any "cheap" ones that were easy to modify for continuous rotation.
Try this;
Rich H
Rich H
