Test Rig kits for sale any questions?
Platform Tester Module
For my propmodules and the lcd breakout boards i needed a good test rig so I got some generic PCB made up. I got more then I needed so I send Gadget Gangster the left overs so you could use them also.
I am not sure if my description makes it obvious if it will work for you. Anyone have any questions or advice so I can make a better description?
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
Post Edited (mctrivia) : 1/22/2010 6:42:24 PM GMT
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Since there are only 32 io pins on the prop which is being used to test the board for more then 32 pins you need to add extra glue logic to the board. Any unused area on the top and bottom PCB can used for adding of glue logic. If more area is needed using one of the following boards with it would work well.
www.gadgetgangster.com/find-a-project/56?projectnum=176
www.gadgetgangster.com/find-a-project/56?projectnum=254
if longer header pins were used these boards could be soldered to the headers of the test rig making them 1 piece so your rig will not brake when changing. However so far I have not needed any more area then what is available on the rig.
If these sell I promise to keep Gadget Gangster well stocked. I can have 200 more kits to Gadget Gangster in 17 days if he sells out on the 15 I have sent so far.
I am selling because my minimum order was 23 and I figured others could use.
