NTSC to VGA?
Oldbitcollector (Jeff)
I know there are a number of products (priced from $40-$99) which will
convert NTSC video output to display on a VGA monitor. (scan conversion)
Does anyone know of any chips/circuits which do this that could be incorporated
into a Propeller protoboard design? In other words, has anyone gotten this down
to a science without having to order an additional box and wall wort solution?
OBC
New to the Propeller?
OBC
An NTSC to VGA scan converter is just a complex piece of machinery whether you build it yourself on a Protoboard or buy a ready-to-go unit. You basically need an NTSC display that writes to a pixel frame buffer (like 640 x 420), then a VGA display at that resolution. You need at least a 32K buffer as well.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
