Experiments with renewable energy BS2px
Is there still support available for The "Experiments with renewable energy" project files?
I am haviing trouble getting the data to plot from my bs2px to stamplot pro.
Here is my source code:
' Experiments with Renewable Energy v1.0 - PlotIt.bs2
' Transmits acquired data to StampPlot software for plotting.
' {$STAMP BS2px}
' {$PBASIC 2.5}
'· Declarations
For Plot_It Subroutine
· ch0········· VAR···· Byte················· 'Voltage reading from A/D CH0
· ch1········· VAR···· Byte················· 'Voltage reading from A/D CH1
· ch2········· VAR···· Byte················· 'Voltage reading from A/D CH2
· ch3········· VAR···· Byte················· 'Voltage reading from A/D CH3
· checkSum···· VAR···· Byte················· 'Sum of all of above readings
'· Main Routine
Main:
DO
· GOSUB Exp_1······························· ' Programmable Battery Charger
· GOSUB Exp_2······························· ' Dueling Solar Cells
· GOSUB Exp_3······························· ' Solar Cell Sun Tracker
· GOSUB Exp_4······························· ' Half&Full Wave Rectification
· GOSUB Exp_5······························· ' Three-Phase AC Alternator
· GOSUB Plot_It····························· ' Plot Data w/ StampPlot Pro
LOOP
'· Subroutines
'· Experiment 1: Programmable Battery Charger
Exp_1:
Exp_1_End:
· RETURN
'· Experiment 2: Dueling Solar Cells
Exp_2:
Exp_2_End:
· RETURN
'· Experiment 3: Solar Cell Sun Tracker
Exp_3:
Exp_3_End:
· RETURN
'· Experiment 4: Half and Full Wave Rectification
Exp_4:
Exp_4_End:
· RETURN
'· Experiment 5: Three-Phase AC Alternator
Exp_5:
Exp_5_End:
· RETURN
'· A/D Converter Routine
A2D:
A2D_End:
· RETURN
'· Plot Acquired Data Using StampPlot Software
Plot_It:
· checkSum = ch0 + ch1 + ch2 + ch3·········· ' Compute checksum for StampPlot
· DEBUG ch0, ch1, ch2, ch3, checkSum········ ' Transmit data to StampPlot
· PAUSE 250································· ' Give StampPlot time to plot data
· ch0 = 25··································· ' Reset voltages and checkSum
· ch1 = 50
· ch2 = 75
· ch3 = 100
· checkSum = 0
Plot_It_End:
· RETURN
I am able to get data in stamp editor debug and hyperterminal.
Can't figure out why not in stamplot???
Suggestions?
Thanks in advance.
' {$STAMP BS2px}
' {$PBASIC 2.5}
'· Declarations
'· Main Routine
Main:
DO
LOOP
'· Subroutines
Exp_1:
Exp_1_End:
· RETURN
Exp_2:
Exp_2_End:
· RETURN
Exp_3:
Exp_3_End:
· RETURN
Exp_4:
Exp_4_End:
· RETURN
Exp_5:
Exp_5_End:
· RETURN
A2D:
A2D_End:
· RETURN
Plot_It:
· ch1 = 50
· ch2 = 75
· ch3 = 100
· checkSum = 0
Plot_It_End:
· RETURN
Suggestions?
Thanks in advance.
We do not have the Renewable Energy kit anymore, however you can still download the PDF to review (see link below). Regarding StampPlot; what is the COM port that you are using for the BASIC Stamp 2px module? Also, what version of Windows do you have currently running?
"Experiments with Renewable Energy" v1.0 (310 pp.)
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Web_EWRE%201.0a.zip.zip
Respectfully,
Joshua Donelson
www.parallax.com
