need help with TowerPro MG995 servo
The towerPro MG995 servos can only rotate -90 to +90.
I know the center for the TowerPro MG995 servos is 1500. Is the TowerPro MG995 servos programmable like the continuous rotation servo using Basic Stamp. If so how can I center TowerPro MG995 the servo using basic stamp v2 code? Thanks
Post Edited (thangngoc) : 1/20/2010 8:07:49 PM GMT
PULSOUT 12, 750 ' output of pulse on pin 12
750 is the pulses it would send out on pin 12, the bs2 stamp operates at 2us, so 750 * 2=1500
DO
PULSOUT 12 , 1500
PAUSE 20
LOOP
The arm of the servo rotated 180 degree then stop.
Sorry for the misinformation, was being distracted. i have found 1100 to 1300 will max some servos while 1400 to 1500 is fine. this is something you will just have to play with and see where your servo max's out at
Post Edited (kf4ixm) : 1/21/2010 2:14:55 PM GMT
with your servo hooked to pin 12?
If not go back and do that. Most servos that don't rotate all the way around are centered mechanically by removing the horn and setting it where you want it when you are sending the servo code for 'center'
- Stephen
All a servo does is try to seek a position based upon the width of the pulse that it receives.
PULSOUT 12, 1500 is equivalent to a 3.000mS pulse width. That is likely too much. For general operation you want to use pulse widths that range from 1.000ms to 2.000mS.
If you need more movement out of the servo you can go outside that range but you must experiment to find the limits. The extents of a standard servo's range of travel are mechanically limited, if you use a pulse width that the servo can't reach it will be stalled while it pushes against that mechanical limit.
To center your servo, send a pulse width of 1.500mS (PULSOUT 12, 750). There is no adjustment to make. If you need the servo horn to point a different direction, remove it and reinstall in the desired position. Like Franklin said.
Remember each increment of PULSOUT is .002mS.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Post Edited (W9GFO) : 1/21/2010 3:26:34 AM GMT
You are only sending the pulses to the servo for 1/5th of a second. 10 times through that FOR..NEXT loop only takes about 200mS. If you increase to (counter = 1 to 100), the servo will get pulses for about two full seconds.
According to what I have read about the TowerPro MG995, the pots are low quality and it exhibits significant overshoot. That may contribute to it being noisy when it's not supposed to be moving.
Rich H
