Reading a series bytes
Is it possible to read data of different sizes (ie byte, long) within an array that is not aligned to with prop memory locations. I am trying to read a long of byte aligned data but the results are backwards.
For example I have a GPS string of data that is 16 bytes long.· Some of the data needs to be read as bytes and some as long.· When I read a long, the data is reversed from what I expect.
·· Gives $04D6717E
· but what I was expecting is $7E71D604
Is there a better way to read the data?
What is the fastest way to reverse the order?··
Long[noparse][[/noparse]@GPS_Data[noparse][[/noparse]0]] Dat GPS_Data Byte $7E, $71, $D6, $04, $03, $DD, $00, $00, $C4, $05, $00, $00, $A6, $A1, $02, $00
·· Gives $04D6717E
You are experiencing this because of something called Little-Endian format.
In the Propeller as in Intel Chips and other microcontrollers a Long (or word) is stored in the Least Significant Byte First order (LSBF)
or what is called Little-Endian format.
So if you store 4 bytes A4 65 4B 32 then the number that these 4 bytes represent is actually 324B65A4 = 843802020 (in decimal)
So when you read bytes through a serial port and they come in the order A4.... then you will need to reverse them as shown by Bocefus
OR
you need to store them in the reverse order in the buffer as they come in.
Samuel
www.RobotBASIC.com
bytes[noparse][[/noparse] 0 ]:=gps_data[noparse][[/noparse] 3 ]
bytes[noparse][[/noparse] 1 ]:=gps_data[noparse][[/noparse] 2 ]
bytes[noparse][[/noparse] 2 ]:=gps_data[noparse][[/noparse] 1 ]
bytes[noparse][[/noparse] 3 ]:=gps_data[noparse][[/noparse] 0 ]
' now long_val contains the reversed long
dat
long_val long
bytes byte 0[noparse][[/noparse] 4 ]
gps_data byte .....
Instead of fixed index for gps_data you can of course use an offset and revert not alligned longs in the middle of the gps_data.
Only the long_val needs to be alligned.
This PASM code does not work for unalligned longs.
PS: sorry ... forgot about the [noparse][[/noparse] ] problem ;o)
Post Edited (MagIO2) : 1/20/2010 9:22:45 PM GMT
wordValue := byte[noparse][[/noparse] address ][noparse][[/noparse] 0 ] + byte[noparse][[/noparse] address ][noparse][[/noparse] 1 ]<<8
longValue := byte[noparse][[/noparse] address ][noparse][[/noparse] 0 ] + byte[noparse][[/noparse] address ][noparse][[/noparse] 1 ] << 8 + byte[noparse][[/noparse] address ][noparse][[/noparse] 2 ]<<16 + byte[noparse][[/noparse] address ][noparse][[/noparse] 3 ]<<24
I don't see a big difference to my version above except that I don't need the shift operation. The shift is simply omitted by accessing the single bytes inside the long.
But ... another thing to mention : you did not revert which was a requirement and is needed when you read a big-endian stream and want to use it in the propeller, which stores longs little-endian.
