Cool CCFL Voltage Bargraph
Just got my Parallax CCFLs and they're amazing even in their intended 12-volt function. But check the effect when you vary the voltage (into the Parallax inverter) from 4-8 volts: you get a fairly linear voltage indicator!
http://www.youtube.com/watch?v=1LkNmuupsvo·
Anybody think this is harmful to the inverter or lamp? No magic smoke released yet. Here, the inverter is hooked up to a power supply and I'm manually adjusting the voltage.
Post Edited (erco) : 1/20/2010 12:43:34 AM GMT
Peter KG6LSE.
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
····http://forums.parallax.com/showthread.php?p=851938.
Think light sabers, volume level meters, equalizers, etc.
I haven't detected any harm to the inverter from driving them this way. I think the reason this works is due to the wire that runs alongside the tube to feed the other end. This sets up a field that favors the wired end and excites the gas there before the rest of it can ionize.
I like the 3-color units. I want to use a Stamp to switch it exactly to the 3 voltage steps where the colors change.
Unless you've done that already, too???!!! [noparse]:)[/noparse]
http://www.youtube.com/watch?v=7EOrtHYsgAE
Fun fact: I'm using 3 of my my favorite little Aromat TF2-5V relays here to switch voltages. These 5V, 17 mA relays are being driven directly by the HW board's output pins, each which has an inline·220-ohm resistor, so the relays are operating off of 3 volts or less, and·~ 10 mA. Not all of these type relays will·work properly at this low voltage, these were hand-picked. Pretty sensitive stuff.
CCFLs: http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/ccfl/List/0/SortField/4/ProductID/629/Default.aspx
http://forums.parallax.com/showthread.php?p=852508
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Propeller-Based Reverse Geo-Cache Birthday Present Project
