Timing Quirk — Parallax Forums
Timing Quirk
lockadoclockadoc Posts: 115
edited 2010-01-19 01:57 in Propeller 1
I made a small method to light some leds for an amount of time after a button push than they turn off.
the quirk is that when I change the variableto a larger number the on time goes down instead of up.
I can come up with the number I need for the two different delays I want.But would like to know the why of quirk
Bill S
  • JonnyMacJonnyMac Posts: 9,800
    edited 2010-01-19 01:37
    At some point you're going to roll-over the limit of a 32-bit value and your delays will get smaller. You can save yourself a lot of grief by using a standard timing unit. If you ever used a BASIC Stamp then you're accustomed to PAUSE -- here's how to duplicate that in your programs.
    First, create a constant for one millisecond:
    con
      MS_001 = 80_000_000 / 1_000
    This assumes that you have an 80MHz system (typical). Next create a simple public method:
    pub pause(ms) | t
      t := cnt
      repeat ms
        waitcnt(t += MS_001)
    BAM! You're done, and no more guessing or calculating values for waitcnt. If you want to wait 0.1 seconds, you use pause(100). Want to wait 2.5 seconds, use pause(2_500). Honestly, it doesn't get much easier than that, and your programs will be much easier to follow.
    Jon McPhalen
    Hollywood, CA
    Post Edited (JonnyMac) : 1/19/2010 1:54:33 AM GMT
  • RaymanRayman Posts: 16,272
    edited 2010-01-19 01:45
    I'm tired, but doesn't that code show 1 second waits?
    edited 2010-01-19 01:52
    I'm tired, too -- you're right and I fixed the listing. Thanks for the catch, Ray.
    Jon McPhalen
    Hollywood, CA
  • AJMAJM Posts: 171
    Phew, I thought I was going to have to start re-learning everything.
    Nice code snippet
