I have been scratching my head on how to control the following motor using Parallax components. Please see the pictures below for motor details. Any ideas?
Bill, Leon ... thank you so much for your feedback! Yes, I figured that driving the motor with the Propeller would be somewhat complicated. Actually, I didn't get anywhere when I tried. I will take a closer look at a dsPIC as Leon suggested.
You are most welcome... but I think it would be a LOT cheaper to simply use a regular DC stepper motor, gear motor, or servo [noparse]:)[/noparse]
CurdZechmeister said...
Nice looking pics of the motor. BTW, where did you pull the motor from? I was thinking it might be another clue for what kind of motor is, but it sounds like Leon may have the answer for you.
Timothy D. Swieter, E.I. www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT www.tdswieter.com
Thanks for the many responses to the pictures above, i really appreciate it. The motor is part of an aircraft instrument, hence the 400Hz and because of the odd form factor of the motor I have not been able to put a regular DC motor/stepper into its place. Creating the 400Hz signal is not overly complicated, I was able to do that simply by pulling some PWM stuff together. However, getting the motor to run smooth is another complication that I ran into. Thanks for the idea with he H-bridge(s), that would work, but it's somewhat tricky to get the right torque on the motor. So I flipped through AN822 and AN892 and AN907 from Microchip and found some helpful stuff in there.
I will post more as I find out more about the behavior of the motor. Thanks again everybody! Love the forum by the way.
Aircraft use 400Hz so that they can reduce the iron mass, so keep the frequency about right. If you reduce the freq the losses get higher and it will overheat, too high a freq and it would probably give reduced output.
Style and grace : Nil point
Looking at the drawing on it, I'd almost think it was a three coil stepper, but the disparate voltages give me pause.
I'd try tying green to red/black, and treating it like a bipolar stepper motor, and try driving it with 18V or so.
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
5.0" VGA LCD in stock!
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Leon
Amateur radio callsign: G1HSM
Thanks again!
Leon
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
www.tdswieter.com
Look up AC servos. There is a lot more to it than using an H-bridge and some simple software.
Leon
Post Edited (Leon) : 1/19/2010 10:03:07 AM GMT
Curd.
