Cable to Connect Multiple Stamps Together
I would like to connect together·many of the pins on 5 Stamps, using Super Carrier Boards. There's a 'block'·on the·board that has 20·electrical connectors (2 rows of 10) for 2 x VSS, VIN, VDD and pins·0 to 15, and it's this I'd like to use.
I·have been looking for·a flat 20 connector ribbon cable, and·crimp on headers (Kind of·like the old PC drive cables).
I've just returned from Frys (a truly frustating experience), and they have nothing. Can anyone help·me with part numbers·from someone like Mouser, etc?
Thanks, John Burrow
San Diego
Thanks, John Burrow
San Diego
I wouldn't recommend tieing the VDD pins together.Instead tie the VSS pins together and the VIN pins together if using one power supply.This way each super carrier board has its own voltage reg.(VDD).
I would also use a 220ohm resister between I/O pins to prevent a dead short.
One last thing,If you tie all the I/O pins together you will in effect have just one Super Carr. Board,wasting the other 4
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
