Piano Delayed Mute Problem
                    I am working on a synthesizer project that uses a PS2 keyboard and the comboKeyboard object. I am having trouble coming up with a method so that when you press a key the note is played, but it dies out after a while. I could do it so that the propeller just loops for a delay and then turns off the note, but that does not allow another note to cut off the first note.
My attempt uses a timer that is set when a key is pressed and then decremented until it is at zero, at which point the sound is turned off. For some reason instead of the sound turning off after a delay it just remains on, although it is not stuck in an infinite loop, as I can hit other keys and it switches to that note.
Here is my code:
Not the fish.
sites.google.com/site/bitwinproject/
Here is my code:
  timer := 0
  repeat
    keyval := key.getkey
    key.clearkeys
    repeat i from 0 to 32
      if keyOrder[i]==keyval
        note := (i+1)*3+1
        timer := 500
    if timer>0
      noteOn(1, note)
      timer--
    else
      noteOff(1)
      timer := 0
DAT
keyOrder byte "z","a","q","x","s","w","c","d","e","v","f","r","b","g","t","n","h","y","m","j","u",",","k","i",".","l","o","/",";","p","'","[noparse][[/noparse]","]"
[/i]
Not the fish.
BTW, you can avoid the problem with [noparse][[/noparse]i] disappearing and changing everything after it to italics by using my code formatter at www.phipi.com/format.
timer := 0 [b]repeat[/b] [b]if[/b] key.key>0 keyval := key.getkey key.clearkeys [b]repeat[/b] i [b]from[/b] 0 to 32 [b]if[/b] keyOrder[noparse][[/noparse]­i]==keyval note := (i+1)*3+1 timer := 50 [b]if[/b] timer>0 noteOn(2, note) timer-- [b]else[/b] noteOff(2) timer := 0(thanks for the link to that nifty code formatter)
It still does not work. If I am right then this code now checks for a keypress before calling getkey like you recommend, but the note still hangs indefinitely. Am I right in saying that the timer variable is not decrementing? How can that be so when I know that the code under "if timer>0" is being called (because I can still change the note by pressing another key)?
Not the fish.
The cog would just go through an array decrementing a bunch of variables and map the volume of the variable to the value currently its decrementing.
When the value its decrementing equals zero it turns the note off.
Then the cog that is getting the notes can just put change the value of the next note played back to 1000 or something and then get the next note.
Nyamekye,
if (keyval := key.getkey) repeat from 0 to 32 ... if (timer) ...-Phil
timer := 0 [b]repeat[/b] [b]if[/b] (keyval := key.getkey) [b]repeat[/b] i [b]from[/b] 0 to 32 [b]if[/b] keyOrder[noparse][[/noparse]*i]==keyval note := (i+1)*3+1 timer := 50 [b]if[/b] timer>0 noteOn(2, note) timer-- [b]else[/b] noteOff(2) timer := 0..And kye, thanks for that method. I'll attempt it if I can't get this Spin code sorted out, but my PASM skills are very weak and I don't know the exact way I would go about accomplishing that.
Not the fish.
if (keyval := key.key) ...-Phil
No. Then it would only get executed when a new key is pressed.
All the "repeat i from 0 to 32" loop does is set note to a value that corresponds to the position of the key that has been pressed in the order that I have established in the keyOrder data section (shown in the code segment in my initial post). If the "if timer>0" block were in the "repeat i from 0 to 32" loop the noteOn() function would be called 33 times and only when a new key was pressed, which I don't want.
Not the fish.
Post Edited (SciNemo) : 1/17/2010 10:57:49 PM GMT
if (--timer == 0) noteOff(2)Also, at some point you will probably want to learn to use cnt for more accurate timing without having to rely on the Spin code overhead.
Another optimization that will help is to use lookdown instead of your loop to find the value for i.
Post Edited (Phil Pilgrim (PhiPi)) : 1/17/2010 10:31:31 PM GMT
