Trying to rig a Futaba FP-R114H RC Transmitter
Hey, Im fairly new to the wonderful world of Propeller, and I'm trying to rig it, so that I can use it to run a robot. I have a Futaba FP-R114H controller, and I dont quite know how to hook it up. The input signal that will be controlling the robot is an awesome modded joystick that utilizes a 15 port game plug, that will be jumper wired into the breadboard. If anyone knows anything about this, then Help would be greatly appreciated [noparse]:)[/noparse]
It begs the question, why not just get a 27 Mhx transmitter that will probably have one or two joysticks on it already?
Jim
Emulate the potentiometer voltages that run from the Tx joysticks/controls with a Prop by converting the signals from your fancy joystick in your Prop.
BH
If you want to use an RC system to remotely control a robot I would start by using a regular RC transmitter to send the signals to the propeller via the RC receiver.
Really, to be helpful we need to know more about what you are wanting to do.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Signature space for rent!
Send $1 to CannibalRobotics.com.
Post Edited (Destructinator) : 1/16/2010 6:00:34 PM GMT
sended out by a 27MHz RC-transmitter.
So if you want to keep the joystick with the 6 buttons you would have to connect
this joystick to a 27MHz RC-transmitter. It would be much easier to use a standard 27 MHz RC-control.
The propeller can be connected to the 27MHz-receiver instead of servos when using the right
"servo-signal-driver" from the obex and an some resistors.
As you want to control the robot wireless with a propeller I think it will be easier to use
a wireless serial-data connection.
best regards
Stefan
Just a thought
Using the propeller chip to control the transmitter via a trainer cord is an option but I think you would be better off using the propeller on the robot.
I would suggest getting a 6 channel (or more) RC transmitter/receiver set in either 75 mhz or 2,4 ghz (72mhz is for air).
Use one stick to control the up/down + left/right aiming and the other stick to drive the robot. The radio will have a couple other switches which could be used for fire and charging of the air compressor. If you get a heli radio one of the switches will be a three position switch so that should work well since you said you needed two buttons for the compressor.
The propeller chip would be connected up to the RC receiver and could be used to monitor and/or automate the compressor.
Rich H
