Parallel LCD with BS2
Hey Everyone,
I seem to have a parallel and serial LCD with four pins on the side and sixteen on the bottom. The extra two pins on the parallel connection is for the backlight. As for the serial connections, two of them are soldered to and two are unused. The LCD is a GX1602A5.
I want to experiment with the LCD and write messages for it to display, how can I do this? Apparently with the BS2 (I have the Boe-Bot Board of Education), I have to manually create subroutines. How do I do that?
I'd appreciate it if you guys guided me into programming this LCD as well as connecting everything!
Austin
Austin
- Stephen
Does anyone know how to connect and program a parallel LCD? Also, does anyone know of any documentation on the parallel LCD Franklin is talking about?
Austin
Here is the Parallax documentation and some demo code.
--Bill
You are what you write.
