How to store datas in the data logger....desesperate!
Hello! I am actually working with the BASIC STAMP 2px to control a gyroscope....We decided to add the data logger to store the data, but my problem is that I don't know how to do it....I have conected the dataLogger to the basic stamp and I have tried to run the test code, but it stops in the "Syncronizing" message and don't give me any other message.....I don't know why could it be....Could someone help me? I am desesperate with it!! Thanks!
Powered by enthusiasm
"Baud CON 84 ' Serial Baud Rate 9600 bps (BS2)"
I don't know what the new value for the 2px should be though...
Should be easy to find out
"You do not really understand something unless you can explain it to your grandmother."
-Lucky[size=-1][/size]
The essential components are:
1. The four pin definitions for Chip Select (USBCS) Data In (USBDataIn)·Data Out (USBDataOut) and·SPI Clock (USBClk).
2. Two preable constats for·writing and reading:
USBPre_W····· CON·· %100
USBPre_R····· CON·· %110
3. The two subroutines to read/write a byte from the device:
USB_Write:
· HIGH USBCS
· SHIFTOUT· USBDataOut, USBClk, MSBPOST, [noparse][[/noparse]USBPre_W\3, IoByte\8]
· SHIFTIN·· USBDataIn, USBClk, MSBPOST, [noparse][[/noparse]Status\1]
· LOW USBCS
· PAUSE 1
RETURN
USB_Read:
· HIGH USBCS
· SHIFTOUT· USBDataOut, USBClk, MSBPOST, [noparse][[/noparse]USBPre_R\3]
· SHIFTIN·· USBDataIn, USBClk, MSBPOST, [noparse][[/noparse]IoByte\8, Status\1]
· LOW USBCS
· PAUSE 1
RETURN
' {$STAMP BS2px}
' {$PBASIC 2.5}
'Programa de prueba para escribir los datos del giroscopo en el data logger
I/O Definitions
TX PIN 1 ' Transmit Data --> 27937.4 (RXD)
RTS PIN 2 ' Request To Send --> 27937.6 (CTS)
RX PIN 3 ' Receive Data <-- 27937.5 (TXD)
CTS PIN 4 ' Clear To Send <-- 27937.2 (RTS)
Constants
Baud CON 396
Variables
value VAR Byte
cont VAR Word
cont2 VAR Word
Inicialization
DEBUG CLS, "Program to record data and store it on a data logger", CR, CR
PAUSE 2000 ' Allow Time To Settle
HIGH TX ' Initialize Transmit Line
LOW RTS ' Take Vinculum Out Of Reset
' Delete SEEDFILE.TXT if one exists, ignore error if no file exists
PAUSE 500
SEROUT TX\CTS, Baud, [noparse][[/noparse]"DLF seedfile.txt", CR]
SEROUT TX\CTS, Baud, [noparse][[/noparse]"OPW seedfile.txt", CR]
FOR CONT2 = 0 TO 50
FOR CONT = 0 TO 1500
LOW 12
SHIFTIN 9, 11, MSBPOST, [noparse][[/noparse]value\9]
HIGH 12
WRITE cont, value
DEBUG DEC5 value
SEROUT TX\CTS, Baud, [noparse][[/noparse]"WRF ", $00, $00, $00, $07, CR, DEC5 value, CR, LF, CR]
NEXT
NEXT
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CLF seedfile.txt", CR]
DEBUG "CLOSED"
END
How could I use the trim???Or would it work with the SPI mode?...Thank you so much!!!sooo much!!
