Current limiting with resistor divide
I am using a oil temperature sensor that measures about 50 ohms when cold and decreases with temp. If I wire 5v-50ohm-sensor-ground my 5 volt regulator chip is over heating. I am also using a simple variable resistor in the same manner.
Because of the range of the resistors 25-100 ohms, how can I limit the current and still use these resistors? I am sure this is a simple question but I have been stumpted for months now.
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
A series resistor of 500-5000 ohms would be a simpler current source but would be somewhat less accurate. The op amp would still be required.
You could use a current mirror such as this one. When powered with a 5V supply, the differential output provides roughly 40mV per Ohm of change from the sensor using about 400 micro amps of current through the sensor.
Beau Schwabe
IC Layout Engineer
