"No Basic stamps found." trouble shooting
Where can·I find a guide or documentation to walk me thru trouble shooting the error message "No Basic stamps found"?
I have had my software running for a couple of months now even programed a few projects and a bot that worked untill I scabbed off all the parts. Tonight·in the middle of learning about "Ping", while doing some "cut a paste" of·a program up pops the Error message.
Checked power source, even plugged in a different board with a different stamp on it still the error message? When the down load starts I can see that it finds the Loopback and the Echo just before·I get the Error?
Nuby
Nuby
The Stamp has to be working for it to be found by the Stamp Editor. The Stamp and the Editor talk to each other. If the Stamp doesn't talk back, the Editor complains.
For the Stamp to work, it must have power and it must not be broken. It's hard to break a Stamp, so that's an unusual reason for "No Basic Stamps Found".
For the Stamp Editor to talk to the Stamp, there has to be a working bidirectional serial connection between the two. If you're using a serial port, the port has to be working, the serial cable has to be working and has to be plugged in on both ends. You can't have any extra adapters on either end that might mix up the connections.
If you're using a USB port and a USB to serial adapter, the port has to be working (including the USB driver), the USB cable has to be intact, and the USB to serial adapter has to be working. The USB to serial adapter has to properly implement the various handshaking lines like DTR, RTS, CTS, and DSR. Many brands of adapters don't do this and won't work for downloading Stamp programs. Most adapters made by FTDI or using an FTDI chip set work fine. The Keyspan High Speed Serial Adapter also works fine.
If you're using a USB port, remember that the standard Windows driver won't work for programming Stamps. You have to have the FTDI driver (for FTDI adapters) or Keyspan driver (for the High Speed Adapter) properly installed.
What real gets me is it was working one minute then stopped.·Thought·I might have changed a set-up or something and rebooted the computer to see if it would "fix" itself, no luck. Also went to the "Preferences" in the BS editor·and set what·I could back to default. The baud rate it is at 9600.
Nuby
We're a little in the dark still about what you're working with.
Is the Stamp mounted on a board of some sort? Which kind of board? Are you using a serial-USB converter of some sort? If so, Parallax or other? What's your power source?
If it was working and then stopped, it sounds most like a power problem, right? When you say that you checked the power source, what did you do? Are you using batteries or a wall wart or what?
Going to check it out with a better power source, maybe buy a new battery. Will take it to another computer that a friend has with the same software and see if it is ok for him.
Will report back tonight.
Thanks for all your help!
Nuby
Perhaps a silly question, but...you do have the slide switch turned on, right? That is, you have it on 1 or 2, not 0?
Also do you have any circuitry attached to the board while you're testing it? If it were me, the first thing I'd do would be pull all of the wires from the headers and try to get the Stamp·to respond on its own.
As it turns out it was my "mickey mouse" power source set up. I have learned a very big lesson here thanks again. I am back to work on my little project.
Nuby
Glad to hear it's going again.
Can u tell exactly what you did to solve your problem, found a new Power Source???????
