GPS troubles
I'm currently working on a project that finds the latitude and longitude and stores the information on a data logger.
I got everything working properly except that the latitude and longitude isn't accurate enough; 72 dgrees longitude could be anywhere from boston to 100 miles in!!
· I was wondering if this is just a limitation of my gps (PMB-248 GPS reciever from parallax) or is my code missing something.
I'm using GPS_IO_Mini_PNAV thats slightly different·as an object to read the incoming data and Numbers to create the string.
gps.readNEMA 'Finds an NEMA string lights(1)
USB.OpenForWrite(string("data.txt")) 'Writes to the data.txt file and records USB.WriteLine(string("longitude is...")) USB.WriteLine(num.ToStr(atoi(gps.longitude,3),Num#DEC3)) USB.WriteLine(string("Latitude is...")) USB.WriteLine(num.ToStr(atoi(gps.latitude,2),Num#DEC3))
--jc
