Pro Biped
I'm planning to pair the 'Propeller Robot Control Board' with the 'Lynx Motion BRAT' this week. I was wondering if anyone else had started experimenting with a Propeller driven biped?.
EDIT: Added Links.
Post Edited (Nishi .) : 1/12/2010 10:17:18 PM GMT
EDIT: Added Links.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Thank you [noparse]:)[/noparse] , is there a way to post video in the parallax forums? If not then you can either also follow my progress at Trossen Robotics ----> forums.trossenrobotics.com/showthread.php?p=37776#post37776 or subscribe to youtube.com/NishiYAOW
www.youtube.com/watch?v=kpqVJnW6xgI
Post Edited (Nishi .) : 1/27/2010 2:28:06 PM GMT
PG
Style and grace : Nil point
best regards
Stefan
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
@Toby Seckshund haha I've got two dogs and they have about as much patience where my robots are concerned, there not impressed at all. B***** ey?.... No no I'm joking [noparse];)[/noparse]
@StefanL38 Quite, I'm not finding it easy at all but cheers [noparse]:)[/noparse]
@mctrivia, Thanks.
PG
I hear ya tho.
No to slow progress over here (But I posted anyway) -> Learning to walk
Was going well @ First, I Thought we were starting to get Somewhere...
www.youtube.com/watch?v=g1CzXqSzWOE
...But then, he begins trying to kick invisible water bottles???
www.youtube.com/watch?v=ZyYhUCQpDSQ
So I was getting frustated. . in the end I think he decided to call it a night.
www.youtube.com/watch?v=6lzbVKUlXzs
Post Edited (Nishi .) : 1/29/2010 4:25:03 PM GMT
I know, I know I should have just used an Atom Pro and Bot Board II but I had the MSR1 there, and its all so much fun.
It has ramping-functions to make the movements smoother.
another idea: somewhere there was a program that SENSED the servo-position. Could this be used to create some kind of a TEACH-IN-function?
I mean. Unpower the servo, move the position of the servo to a new position BY HAND, and then sensing the new position
or would a set of move forward / backward buttons help to move each servo to its next position and then press a button "store position"
best regards
Stefan
·http://forums.parallax.com/showthread.php?p=582447
I was never a fan of the term "ramping" in the Servo32 object. The ramp setting just puts a time delay between the current position and the commanded position. It really doesn't do traditional ramping as in stepper motors going from rest to full speed in a controlled acceleration over time.
Jim
Now what could be a short but still self-explaining name for the method?
PUB DelayedMove ?
best regards
Stefan
PG
I missed your reply. I think it best to call it "TimedMove" as is it a move with a specific time period called out. I wanted to call it "slew". When I was working with Photoplotters and Drafting Plotters, we used the term "Slewing". We used it to mean to move to a position on the table, mostly under manual control under a slow speed, (usually with a 4-button pendant). Now looking at the definition of "slew", I'm not sure if that's the right term. But that's what we used at Gerber for 10 years.
Jim
Post Edited (hover1) : 2/2/2010 8:36:21 PM GMT
Quick update tho.
I had to order a few parts and make a tamiya to barrel adapter which worked out OK for my first ever bit of real soldering, but then I dropped my robot! .. from about 1 cm in the air on his left ankle.. and it went limp.... [noparse]:([/noparse]
SO I ordered a new one and waited... then had to move living conditions and work, life etc.. got my new ankle servo and while I was changing it (I didn't unplug the battery pack) smoke started coming from everywhere! (.. well the battery and circuit board).. I'd been leaning on the barrel head that was already quit delicately soldered together and I'm guessing I pushed positive and negatives together or something but the power pack plastic is well melted. I ripped the pack out and I'm sure I saved the PRCB.. Anyway I've ordered another pack and I'm waiting... again..
What's that saying?.. Less haste more speed
You can see I've mounted the ping sensor too.. he now resembles that BRAT configuration I first fell in love with. [noparse]:)[/noparse]
KONNOR
TYSHAWN
