I need to measure inclination ( high accuracy)
I read some of the Parallax pdf about sensors.
But I can't find resolution of inclination.
( For me it isn't necessary 8g , only 2g is good but I need accuracy )
Do you know which is the best sensor to measure inclination
and which is the accuracy of it.
Thanks, Joe
Thanks, Joe
- Stephen
Could you use three hobby sensors and average the value and get a much more accurate reading?
woodturner550
I want to use Parallax products for this purpose.
Do you know how can I have better accuracy , more than one grade accuracy ?
I just need to measure from 0º to 15º only but less than one grade
of accuracy . 0,5º accuracy or 0,025º could be good for me.
Any idea ?
Thanks.
- Stephen
did you check out the nuts and volts article on the parallax memsic 2125 page?
http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/col/nv92.pdf
See page 7, it shows the accuracy of tilt down to 1/100th of a degree in the sample code listed.
