No signal from vga connector? Problem solved!
Hi
I have a Propeller Education Kit + VGA-PS/2 Adapter Board Kit.
Now I have tried to test my system with different vga-demos. None
of them have not worked. When I connect a monitor to the Propeller's vga connector,
the monitor won't say anything.
What shoud I check to solve the problem and have you any good suggestions?
I am quite sure that there is not wiring problems and not any coding errors.
Post Edited (E-Head) : 1/12/2010 10:12:39 AM GMT
A while back there was a thread where the problem was that the whole propeller stopped, and the regulator got hot, when the VGA was plugged in. I surgested that it might be due to the PIN 9 of the VGA 15 pin being supplied with +5Volts and that may have been shorted to ground if the entire middle row was connected to GND. I never saw a reply to say if the problem had been sorted out, and by what method. PIN 9 gives +5Volts to the VGA monitor so that an EEPROM in it can be read to tell the computer what sort it is, etc. Props do not do that. Some older leads had the PIN 9 removed but not the modern ones.
Do you have an oscilloscope to look at the syncs, are the H and V syncs on the right pins ie you haven't wired anything mirror imaged. The rear of the femail gives the 1-5 then 6-10 then 11 - 15. RGB on 1,2,3 with their shield nominally on 6,7,8. PINS 5 and 10 should be GND. The H syncs are on PIN 13, the V syncs on PIN14, the wrong way around will not work.
An old glass vga monitor might give some clues before it shut down from no signal, LCD just sit there and sulk, if the input isn't good enough
Style and grace : Nil point
