555 one shot
I have a STAMP project where one of the inputs uses a 555, configured as a one-shot. When the 555 is powered, its output pin goes high for 5 sec.
I am ambarrased to say I can not make it work. I want the 555 to simply turn on its output for 5 sec. when its power is applied. I have searched the web and tried many circuits, but none work. They keep the trigger open and require it going o ground to initiate the pulse. I don't want to deal with the trigger or reset pin, just apply power to the 555 and have it output one 5 sec. hhigh pulse.
Any elp would be appreciated.
PS ope it elps.
Cheers,
Tom Sisk
http://www.siskconsult.com
You really don't even need a 555 or 74HC123 for this ... just a PNP transistor, a couple of resistors and a capacitor.
I know you said that you didn't want to mess with a trigger, but if you look at the 'Trigger' in the schematic as if it were your power to a 555 instead, I think this circuit will work for you.
When the 'Trigger is LOW or left floating' the 100uF cap will charge very close to 5V very quickly and draw a minimal amount of 'standby current' once the capacitor is charged (127 micro Amps) ... when you apply 'power' or place 5V on the Trigger, the transistor turns OFF, and the Capacitor discharges through the 39K resistor. It takes approximately 5 seconds for the voltage across the capacitor to reach 1.4V in this setup. Since the threshold of the STAMP is about 1.4V the STAMP will 'see' this as a LOW only when the capacitor falls to this level or below.
If you need to make adjustments to the time, you can substitute the 39K resistor with a variable 100K Pot.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 1/11/2010 11:28:27 PM GMT
