Basic stamp communicating 10mile+ away from one more BS2
what kind of transmitter would i need and how could i use it?
I know its an big question but i need to know.
·But, Digi makes great radios that are good for several times that distance. Check out their XTend line.
They are industrial quality and priced accordingly.
·Cheers,
Tom Sisk
http://www.siskconsult.com
But, if you want to send/receive serial data over several miles, the Digi radios will do it, if you have the antennas properly situated.
Go to the Digi site and check out their products.
Tom Sisk
http://forums.parallax.com/showthread.php?p=759557
I hope this helps.
SJW
http://forums.parallax.com/showthread.php?p=870085
http://www.rfm.com/products/oem_standalone.php
They are new to the market and propriety fhss data modems.
They fall under unlicensed radio fcc limits.
The development costs might be high but for unit price and capability nothing else compares.
Jim
FRS and GMRS radios are not allowed to transmit data! These are VOICE only services. If you wish to transmit DATA on an unlicensed service, consider MURS radios (154MHz). There are 5 frequencies to use, I believe 2 frequencies are narrow band which will limit the data rate that can be used. And yes, these radios are more expensive than throwaway FRS radios. Other considerations would be to use Part 15 devices in the 900MHz and 2.4GHz bands with the appropriate antennas for distance. An important consideration may also be to mount the radios as close to the antennas as possible to minimize transmission line losses.
As far as maximum transmission rates for the amateur 2 meter band, it is limited to 19.2K baud. This is governed by law and not maximum bandwidth of the 2 meter allocation. 56K is allowed on the amateur allocations above 222MHz although operation on the 440MHz band is on shaky grounds in parts of Northern California and Maine due to the Air Force having higher priority to the frequency allocation.
73,
kevin
kc6pob
That is, having a tech license does not entitle you to use FRS for (non-GPS) data. It does entitle you to use 2 meters, as in Ken's project.
They even have a program for the PC that lets you program the aerocomm module through any serial connection. (usb to serial devices)
I have two of these: and using a dual port usb ftdi device I was able to establish a 900mhz link between them through my two com ports on the same computer using the software they provided me with.
lairdtech.thomasnet.com/item/910mhz-modules/ac4490-transceivers/ac-4490-1000m?&seo=110
This is the higher end of radio modules. DES encryption, full serial interface(115200baud, depending on radio link)
This module claims a range of 20 miles and a wattage of 1000mW, approx 700ma power consumption.
