How many others are experiencing software glitches and crashes?
I get a lot of software crashes saying that it cannot connect to the oscope on the port that it was connected to
I also see the software restore/maximize itself, when I try and minimize it
About 80% of the time I have to hit F10 twice to connect, as the first time the software tells me it cannot find the oscope on the ports it scans
I believe I'm forgetting 1 or 2 others, I may start taking screen captures if wanted
I have seen very few errors. Most of the errors I have had were from starting the software before connecting the propscope.
I have had very few problems, and it has been years since I touched an O-scope. I find it works well, and has a pretty fast signal bandwidth.
I am running Win Xp Pro, with a 2.6 Ghz AMD. 1 gig of ram.
I'm not sure what the actual problems are being caused by, but trust when I say it must be very computer specific.
If I were you I would check my USB configurations Under Control Panel>System>Device Manager> System>USB
See if any of the USB items are set to power down. If they are, that might give problems.
Also check to see which version of the Propeller tool you are using. The manual does day if you have an older version it may cause problems.
I wish I could help more.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
There is a way to "force" a device to use a specific COM port that was used by a prior device (try something in the single digits (2-9) that has nothing connected to it. The worst that can happen is that when the device that preciously used that port is reconnected to your system, it will have to go through the "new hardware" setup.
If I remember right, on WinXP Pro,you can force a connected device to use a specific COM port by going to:
My Computer, Properties, Hardware (tab),·Device Manager (button), expand the "Ports (COM & LPT)" item,·right-click the device (PropScope)·and select Properties, select the Port Settings (tab), click on Advanced (button) and then select a new COM port.·You'll probably see a number (probably up to COM17 in your case) of ports marked "(in use)". Just pick one that you know isn't currently in use based on the ones shown in Device Manager. You will get an·warning message if you choose one of the (in use) ports. Click OK and continue.·Forcing a new single-digit COM port may not fix your errors, but it's worked for me on several occasions and it shouldn't make the problem any worse.
Duffer
Mine seems to be a hardware problem but before that when I was trying to use mine I would get a lot of problems with the proscope disconnecting it was really bad if I had my prop proto board connected at same time and was trying to use it both the Prop IDE and the Propscope would hang and I would have to reboot my machine. I am running Vista / Windows 7 and I even tried a clean install of Windows XP I have not bothered to try and use it so I am not sure if there are any mroe updates but at the time I had updated the software per Hanno instructions that did not help any of my problems
@ Mikediv, I did have my prop proto board hooked up, it'd be pretty sad if the propscope and prop chip had a conflict with each other, I hope this isn't the case. I also had viewport open at the time, sometimes. I have version 1.0.2
I have XP sp3 on my dual core 2.6ghz laptop, with 4gb of ram.
Have you found the solution for the problem you were having???
Hanno is aware of my problems and is working on a resolution.
If I were to guess I would say your issues are related to device conflict.
BH
Uninstall the programs and then go to the control panel and uninstall the drivers. Then reinstall each·software one by one.·See what Com Ports show up then.
.......AND get all the CURRENT revisions of the programs before you start the proccess. The current version of PropScope is 1.0.3 and the current version of Propeller Tool is 1.2.7
Jim
