Build Your Own Robot - NEW Robot Base Kit
Build your own robot with the new Robot Base Kit! - $29.99
The Robot Base Kit is a plywood platform kit for the 12V Motor Mount and Wheel Kit (#27971) and the Caster Wheel Kit (#28971). With this kit you will be able to build a nearly complete robot. You can then add on your choice of processor and sensors (sold seperately).
Features:
For more information visit http://www.parallax.com/tabid/145/ProductID/635/Default.aspx
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
Features:
- 18” diameter round robot base provides zero-turn radius
- Pre-drilled mounting locations for two motor bearing blocks
- Pre-drilled mounting locations for up to 10 Ping))) Ultrasonic Sensors and Protector Stands
- Pre-drilled mounting locations for two caster wheels
- Under-carriage battery pack mount location for 12V 7Ah batteries (designed for Power-Sonic PS-1270 or PS-1272 sealed lead-acid batteries)
Lauren Davis
Marketing Manager
916-624-8333
ldavis@parallax.com
