DC Geared Motor Recommendation?
Just wondering if anyone had a recommendation for a low RPM, high torque motor, or place I can find a motor with the following characteristics:
RPM around 400 to 1000
Torque around 30 inch-pounds or equivalent
24 volts max, 12 better
I’ve checked many of the usual suspects: all electronics, and other popular sites. Nothing yet. Or at least, nothing I’m sure of.
Thanks.
Thanks.
http://www.robotmarketplace.com/products/motors_geared.html
Another option is this
http://www.andymark.biz/am-0518.html, with the CIM motor its designed for. I have used the motor and the larger version of this gearbox without problem.
http://cgi.ebay.com/PITTMAN-396-RPM-24V-DC-LO-COG-ROBOTIC-GEAR-MOTOR_W0QQitemZ380192707074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5885405202
These are high quality motors, which you can pick up on eBay for about 5 pounds, or 10 US$
Rough spec...
With approx 12v slow speed draws from 1.79A thru 2.2A
fast speed draws from 3.23A thru 3.5A
12 twisted axis poles so no cogging
Fast is 3180 RPM ~ 50 RPM out of gearbox
Slow is 2640 RPM ~ 42 RPM out of gearbox
Gearbox is a 63:1 reduction
Easy to add a tachometer to these things, just bounce some Infra Red off the amature.
