Any circuit example of PushButtonLedTest for PPDB?
I have the Propeller Professional Development Board instead of the Propeller Education Kit. And I want to do the example of PushButtonLedTest. How should I begin? How do I connect the wire? Thanks
Post Edited (thangngoc) : 1/8/2010 7:45:56 PM GMT
If you take a look into the schematics of the PPDB you can see that
- the pushbuttons are already connected with pull-up-resistors
- the LEDs are already connected with current-limiting resistors
So you simply plug a wire - one end of the wire into the female connector from a propeller-IO-pin and the other end of the wire into the female connector of the LED or pushbutton
That's all.
best regards
Stefan
