Memory Stick Datalogger as a HID Controller
School finally got past the "Science Fair" and I've finally got some time to get back working on my robot Sparkey. I've gotten tired of lugging around a notebook to allow me to use a game controller to drive him and have decided to build a dedicated controller module. As part of this effort, I've been looking at methods to interface a BS2px with a Philips SGC2909BB/27 Game Controller.
For one of the experiments in the "Science Fair", the student requested I build a module to measure and record the data in his experiment. To support this, I bought the Memory Stick Datalogger (#27937) and a USB jump drive. As it turned out, I was able to use the teachers PC and the Parallax PLX-DAQ Spreadsheet tool to log the data directly into Excel.
Reading the datasheets on the data logger, I noticed that the default software would also support a HID on the port and decided to see if I could get it to read a game pad. And it does.
The wiring for the attached code is simple:
Memstick Pin Connect to BS2px Pin:
1 Vss
2 Pin 4 (USBDataIn) I always have to remember the the Serial Data Output for the device is Input to the Stamp
3 Vdd
4 Pin 5 (USBDataOut)
5 Pin 6 (USBClk)
6 Pin 7 (USBCS)
7 No Connection
8 No Connection
Also to use this code, the Jumper must be in the SPI position before the Data Logger is powered up.
Caveat: The only game controller I have this working for is the Philips unit listed above.
Reverse engineering the Philips unit, I came up with the following:
Data Packet - 6 Bytes Total
Byte 1
Left Joystick Horizontal 0=full left 128=Centered 255=full right
Byte 2
Left Joystick Vertical 0=full up 128=Centered 255=full down
Byte 3
Right Joystick Vertical 0=full up 128=Centered 255=full down
Byte 4
Right Joystick Horizontal 0=full left 128=Centered 255=full right
Byte 5
Button Status (Active High)
Bits 0 to 3 = Top Hat Control (my springs are loose and I get non-consistant output)
Bit 4 - Button 1
Bit 5 - Button 2
Bit 6 - Button 3
Bit 7 - Button 4
Byte 6
Bit 0 - Button 5
Bit 1 - Button 6
Bit 2 - Button 7
Bit 3 - Button 8
Bit 4 - "Select" Button
Bit 5 - "Start" Button
Bits 6 & 7 - Not in packet
The controller sends a new packet each time a button status changes. The controller sends a continuious
stream of packets any time one of the two analog joysticks is off the center position.
Now to start working on integrating a Propeller Backpack to display the telemetry the robot sends back on the TV monitor and replacing the bluetooth link with a pair of the 433 MHz RF Transceivers. The bluetooth link is in the same frequency band as the TV security camera and causes interference.
1 Vss
3 Vdd
5 Pin 6 (USBClk)
6 Pin 7 (USBCS)
7 No Connection
8 No Connection
Byte 1
Byte 2
Byte 3
Byte 4
Byte 5
Bit 4 - Button 1
Bit 5 - Button 2
Bit 6 - Button 3
Bit 7 - Button 4
Byte 6
Bit 0 - Button 5
Bit 1 - Button 6
Bit 2 - Button 7
Bit 3 - Button 8
[noparse][[/noparse]First off: I realize that I have taken the topic away from 'Completed Projects' but I am unfamiliar with the proper procedure. Therefore please feel free to transfer this to another forum.]
I read your project with great interest as I have been trying, without success, to use a USB output sensor [noparse][[/noparse]a barometric altimeter - UP24WT from www.ramseykits.com] as input to the Stamp. I was especially pleasantly surprised to review your program statements in regards to reading a USB port.
As I am not knowledgeable in USB interfacing I was wondering if I might prevail upon you to help me code the necessary statements to read some ASCII data into the memstk/Stamp? The data takes the form of the following:
Baudmodes anywhere from 4,800 8,N,1 to 36,800 8,N,1; with 38,400 8,N,1 suggested for speed and reliability.
In order to request the UP24WT to send altitude data, the necessary command to the unit is:
G EL<CR>.
The unit then returns [noparse][[/noparse]example {in feet}]:
1203.5ft<CR><FL>
Any help will be greatly appreciated.
cheers, David
I could not find the altimeter listed on the Ramsey site. Do you have more information on the model?
http://www.ramseyelectronics.com/site/default.asp?search=UP24B&page=search&x=11&y=7
However, one needs the manual [noparse][[/noparse]which I have] to get the details on the requirements for downloading the altitude, etc. data. And Ramsey does not supply the manual as a download.
If you are interested, I can make a copy of the pertinent pages and send them to you.
cheers, David
Two corrections to my previous posts:
The maximum baudmode is: 76,800 8,N,1 [noparse][[/noparse]and not 36,800]
Secondly, I have located the download site for the UP24 manual:
http://www.ramseyelectronics.com/downloads/manuals/UP24B.pdf
This·issue of the manual·however does not include the paragraphs on 'Using the USB port' as was given in the· manual sent with my unit. I wonder if these paragraphs are included in the software download .exe which contain the drivers for exporting the altitude, etc. data to a PC. Will try to locate or scan in these paragraphs.
cheers, David
P.S. Can the Memory Stick Datalogger support two USB devices simultaneously? Are the four open holes on the PCB a place where the second USB connection can be made?
