Ping: Midi Controller- false object detection
This is my first stamp project and my first forum posting. I have looked through the other forum posts relating to the Ping, but have been unable to find posts relating to my particular problem. Please let me know if I need to provide any further details of my project.
I have a built a theremin-style midi controller, utilizing two Ping Ultrasonic sensors and the BS2. The controller works great in a "quiet" enviornment. However, when put into tight rehersal and performances spaces, it receives false hits.
The controller is played in a live electronica band- computers, drums, bass, trumpet, and trombone. The controller seems to be sporadically detecting hits from the trumpet and cymbals. The severety of the situation fluctuates, depending on the size/shape of the performance space.
When we tested one instrument at a time, the false hits occured in a patteren that could be related to the height of the performer and the direction in which he was playing. So, it does seem to be a result of soundwave collisions, or the receiver detecting 40khz waves from other sources.
Currently, the workaround for this problem is turning the sensors off with a switch (SPST and main power supply) when the controller isn't being played. I would like to find a more refined way to deal with this. I'm hoping there are small changes I can make to the physical design to prevent the false detection. I'm also hoping this won't need a drastic change in the physical housing, as the performer who I built this for has already spent a couple of months playing/learning the instrumet. I am hesitant to add more code, for fear of slowing down the response time. Yes, a dilemma. However, if someone has encountered this issue in their own projects, and knows a possible code solution, I will post a link to the code.
Possible solutions I have considered include adding another sensor, such as an IR switch, or adding acoustical treatment. I have researched acoustic treatment, but as of yet, have not found anything specifically rated for ultrasonic waves.
Measurements of the Ping boxes are: 3.5"x2.5"x1.5". The sensors are recessed 2cm inside the box.
Any advice, insight, etc would be greatly appreciated!
Nicole Carroll
aka n0izmkr
www.nicolecarrollmusic.com
Nicole Carroll
aka n0izmkr
- Stephen
From what I understand, the PIR sensors only output high/low signal. I don't think I could replace the ping sensors with the IR sensors, since I am mapping the sensor's field of view to precise midi values.
Please correct me if I am wrong regarding the PIR output.
Regarding the running median- I'll have to think on this one. I'm not sure it would be the best solution for this application, as I need real-time, precise response, with near zero latency. However, thus far I have had no luck with material barrier solutions, so I'm going to give this a try.
Thank you for your input!
n
Nicole Carroll
aka n0izmkr
- Stephen
