Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
comunication between two BS2 — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
filip911
17
2010-01-07 08:12
edited 2010-01-14 08:09
in
BASIC Stamp
How can i make communication between two basic stamps??
thx
Oper8r Al
98
2010-01-07 11:07
edited 2010-01-07 11:07
Take a look at this nuts and volts article. It should help you out.
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/col/nv81.pdf
Al
allanlane5
3,815
2010-01-07 13:09
edited 2010-01-07 13:09
SERIN/SEROUT is the best way.
JD
570
2010-01-07 18:43
edited 2010-01-07 18:43
Filip911,
There is an example of connecting and some sample program in the BASIC Stamp Syntax & Reference Manual under the SERIN/SEROUT command. Here is a link to the PDF in case you do not have a copy. I hope this helps.
BASIC Stamp Syntax & Reference Manual:
http://www.parallax.com/Portals/0/Downloads/docs/prod/stamps/web-BSM-v2.2.pdf
Respectfully,
J
oshua
D
onelson
www.parallax.com
filip911
17
2010-01-13 17:37
edited 2010-01-13 17:37
is this it
256 x 179
7K
7.2K
stamptrol
1,731
2010-01-13 18:00
edited 2010-01-13 18:00
A similar example is in the Editor Help file under either SERIN or SEROUT.
Tom Sisk
http://www.siskconsult.com
Bill Chennault
1,198
2010-01-14 00:52
edited 2010-01-14 00:52
filip911--
Do you want sophisticated communications or dirt-simple? (Dirt-simple = 1 bit sent from a Stamp to another Stamp as a flag.)
--Bill
You are what you write.
$WMc%
1,884
2010-01-14 02:13
edited 2010-01-14 02:13
filip911
Your PNG. will work. Take a look at ASCII, $HEX, SERIAL, 8N1, echo.
google is your friend. even tough its all in the parallax docs.
The Truth is out there
___$WMc%___
BoogerWoods, FL. USA
filip911
17
2010-01-14 08:09
thx
Sign In
Register
to comment.
Al
Respectfully,
Joshua Donelson
www.parallax.com
Tom Sisk
--Bill
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
