filter capacitor question and so on .
As suggested by members I'm using an H11L1M optoisolator to protect the input on my Propeller. The test circuit in the technical data sheet shows a resistor and capacitor in parallel between the signal source and the opto input. For good measure I also have a zener diode between the opto input and ground. I understand how to size my resistor for a given source voltage to keep from damaging my zener diode and my opto input but I've forgotten which type of capacitor I should use. Also, is the size frequency dependent? My fogged-up old memory suspects the RC time should have a relation to the desired input pass band frequency. The output side of the H11L1M test circuit shows a pull-up resistor between Vcc and the output. Because I'm using a Propeller my Vcc should be hooked to the 3.3 volt rail right?
MOORE'S LAW: The capabilities of electronics shall double every 18 months.
cloyd's corollary: Hardware is easy, software is hard.
Post Edited (yarisboy) : 1/6/2010 8:36:33 PM GMT
Yes.
