How to get value in excel by PLX-DAQ?
I could use eb500 to send data to PLX-DAQ and also set the values in worksheet.
However, I really unable to get data from the excel worksheet.
I search the forum topics about PLX-DAQ, but it seems that don't have this problem.
Could someone enlight me what could be the possible reason?
Wire connection, but i could send out. And I still can't get value even I increased the waiting timeout to 20000mS
The values are integers less than 100 which i believe could be processed by basic stamp.
Thanks alot for you help [noparse]:)[/noparse]
I'm not sure this is what you mean, but are you trying to have the eb500 set values in an Excel sheet (through PLX-DAQ), and then have a BS2 read the values from that sheet at the same time? I don't think that's going to work, because only one of the two devices can connect to the serial port that's connected to that Excel sheet.
Hi, thx for the reply.
I did refer to the help file, set function works well. but get function was not able to work.
I was working on a toy tricycle which i need to make it able to move automatically to the assigned location and avoid all obstacle.
So i need to send the data such as the value of encoder or compass. and computer would based on the data provide to figure the real-time location of tricycle.
hence the computer could tell tricycle how to move to reach the assigned location. i just use bluetooth to send out and receive instructions from computer.
